MediaWiki-API-Ergebnis
This is the HTML representation of the JSON format. HTML is good for debugging, but is unsuitable for application use. Specify the <var>format</var> parameter to change the output format. To see the non-HTML representation of the JSON format, set [https://wiki-de.dmxcontrol-projects.org/api.php?action=help&modules=query%2Biwlinks&format=json <kbd>format=json</kbd>]. See the [[mw:API|complete documentation]], or the [[Special:ApiHelp/main|API help]] for more information.
    "error": {
        "code": "internal_api_error_DBConnectionError",
        "info": "[arLyuRHC_41v59HbytBDuQAAAA4] Exception caught: A database query error has occurred. This may indicate a bug in the software.",
        "errorclass": "Wikimedia\\Rdbms\\DBConnectionError",
        "*": "Wikimedia\\Rdbms\\DBConnectionError at /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/loadbalancer/LoadBalancer.php(1477)\nfrom /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/loadbalancer/LoadBalancer.php(1477)\n#0 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/loadbalancer/LoadBalancer.php(972): Wikimedia\\Rdbms\\LoadBalancer->reportConnectionError()\n#1 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/loadbalancer/LoadBalancer.php(944): Wikimedia\\Rdbms\\LoadBalancer->getServerConnection(integer, string, integer)\n#2 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/database/DBConnRef.php(95): Wikimedia\\Rdbms\\LoadBalancer->getConnectionInternal(integer, array, string, integer)\n#3 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/database/DBConnRef.php(101): Wikimedia\\Rdbms\\DBConnRef->ensureConnection()\n#4 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/database/DBConnRef.php(396): Wikimedia\\Rdbms\\DBConnRef->__call(string, array)\n#5 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/cache/LinkBatch.php(385): Wikimedia\\Rdbms\\DBConnRef->makeWhereFrom2d(array, string, string)\n#6 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/parser/LinkHolderArray.php(223): LinkBatch->constructSet(string, Wikimedia\\Rdbms\\DBConnRef)\n#7 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/parser/LinkHolderArray.php(158): LinkHolderArray->replaceInternal(string)\n#8 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/parser/Parser.php(5079): LinkHolderArray->replace(string)\n#9 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/parser/Parser.php(1712): Parser->replaceLinkHoldersPrivate(string)\n#10 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/parser/Parser.php(726): Parser->internalParseHalfParsed(string, boolean, boolean)\n#11 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/MessageCache.php(1425): Parser->parse(string, Title, ParserOptions, boolean)\n#12 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/Message.php(1422): MessageCache->parse(string, Title, boolean, boolean, Language)\n#13 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/Message.php(1007): Message->parseText(string)\n#14 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/Message.php(1075): Message->format(string)\n#15 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiHelp.php(500): Message->parseAsBlock()\n#16 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiHelp.php(182): ApiHelp::getHelpInternal(DerivativeContext, array, array, array)\n#17 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiHelp.php(72): ApiHelp::getHelp(DerivativeContext, array, array)\n#18 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiMain.php(1904): ApiHelp->execute()\n#19 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiMain.php(879): ApiMain->executeAction()\n#20 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiMain.php(850): ApiMain->executeActionWithErrorHandling()\n#21 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/api.php(90): ApiMain->execute()\n#22 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/api.php(45): wfApiMain()\n#23 {main}"
Abgerufen von „$'"1“
