MediaWiki-API-Ergebnis
This is the HTML representation of the JSON format. HTML is good for debugging, but is unsuitable for application use.
Specify the format parameter to change the output format. To see the non-HTML representation of the JSON format, set format=json.
See the complete documentation, or the API help for more information.
    "error": {
        "code": "internal_api_error_DBConnectionError",
        "info": "[Z3TSIxVt1MAlCBy42Ov5xgAAQRE] Exception caught: A database query error has occurred. This may indicate a bug in the software.",
        "errorclass": "Wikimedia\\Rdbms\\DBConnectionError",
        "*": "Wikimedia\\Rdbms\\DBConnectionError at /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/loadbalancer/LoadBalancer.php(1477)\nfrom /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/loadbalancer/LoadBalancer.php(1477)\n#0 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/loadbalancer/LoadBalancer.php(972): Wikimedia\\Rdbms\\LoadBalancer->reportConnectionError()\n#1 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/loadbalancer/LoadBalancer.php(944): Wikimedia\\Rdbms\\LoadBalancer->getServerConnection(integer, string, integer)\n#2 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/database/DBConnRef.php(95): Wikimedia\\Rdbms\\LoadBalancer->getConnectionInternal(integer, array, string, integer)\n#3 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/database/DBConnRef.php(101): Wikimedia\\Rdbms\\DBConnRef->ensureConnection()\n#4 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/database/DBConnRef.php(707): Wikimedia\\Rdbms\\DBConnRef->__call(string, array)\n#5 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/rdbms/database/Database.php(3154): Wikimedia\\Rdbms\\DBConnRef->getSessionLagStatus()\n#6 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/MessageCache.php(1295): Wikimedia\\Rdbms\\Database::getCacheSetOptions(Wikimedia\\Rdbms\\DBConnRef)\n#7 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/objectcache/wancache/WANObjectCache.php(1689): MessageCache->{closure}(boolean, integer, array, NULL, array)\n#8 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/objectcache/wancache/WANObjectCache.php(1522): WANObjectCache->fetchOrRegenerate(string, integer, Closure, array, array)\n#9 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/MessageCache.php(1328): WANObjectCache->getWithSetCallback(string, integer, Closure)\n#10 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/libs/objectcache/BagOStuff.php(216): MessageCache->{closure}(integer)\n#11 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/MessageCache.php(1330): BagOStuff->getWithSetCallback(string, integer, Closure)\n#12 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/MessageCache.php(1242): MessageCache->loadCachedMessagePageEntry(string, string, string)\n#13 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/MessageCache.php(1126): MessageCache->getMsgFromNamespace(string, string)\n#14 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/MessageCache.php(1097): MessageCache->getMessageForLang(Language, string, boolean, array)\n#15 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/MessageCache.php(1039): MessageCache->getMessageFromFallbackChain(Language, string, boolean)\n#16 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/Message.php(1473): MessageCache->get(string, boolean, Language)\n#17 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/Message.php(970): Message->fetchMessage()\n#18 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/language/Message.php(1075): Message->format(string)\n#19 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiHelp.php(434): Message->parseAsBlock()\n#20 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiHelp.php(182): ApiHelp::getHelpInternal(DerivativeContext, array, array, array)\n#21 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiHelp.php(72): ApiHelp::getHelp(DerivativeContext, array, array)\n#22 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiMain.php(1904): ApiHelp->execute()\n#23 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiMain.php(879): ApiMain->executeAction()\n#24 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/includes/api/ApiMain.php(850): ApiMain->executeActionWithErrorHandling()\n#25 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/api.php(90): ApiMain->execute()\n#26 /www/htdocs/w0063903/wikis.dmxcontrol-projects.org_v1.39/api.php(45): wfApiMain()\n#27 {main}"
