Vorlage:Purge/doc
< Vorlage:Purge
Version vom 5. November 2013, 00:55 Uhr von Phaefele (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „{{Documentation subpage}} {{Tlx|Purge}} produces a link that will clear the cache and rebuild page from the wikitext. ==Purpose== For efficiency in service, …“)
{{Purge}} produces a link that will clear the cache and rebuild page from the wikitext.
Purpose
For efficiency in service, MediaWiki caches pages. Depending on the exact sequence of actions editors follow, one may view an out-of-date version of a given page. This happens most often on heavily-edited pages and on pages which contain an instance of transclusion.
{{Purge}} adds to any page a link that, when clicked, not only reloads the page, but clears the server cache, forcing the page to be completely rendered "from scratch". This is not a one-time solution; generally, editing a page is itself sufficient to purge cache. Rather, it is a measure taken in anticipation of the frequent need to purge.
Examples
Code Yields Result
{{Purge}} Purge Creates a purge link for the page it is used on.
{{Purge|Purge this page's server cache.}} Purge this page's server cache. Creates a purge link for the page it is used on, but with the text "Purge this page's server cache."
{{Purge|page=Hauptseite}} Purge Creates a purge link for Hauptseite.
{{Purge|Purge this page's server cache.|page=Hauptseite}} Purge this page's server cache. Creates a purge link for Hauptseite, but with the text "Purge this page's server cache."
When you are linking to a section, purging that page will cause you to lose the section link.
TemplateData
<templatedata> {
       "description": "A template that produces a link that will clear the cache and rebuild page from the wikitext",
       "params": {
               "1": {
                       "label": "Label",
                       "description": "The label of the purge link",
                       "type": "string",
                       "default": "Purge",
                       "required": false
               "page": {
                       "label": "Page",
                       "description": "The page to purge",
                       "type": "string/wiki-page-name",
                       "required": false
} </templatedata> }}
