Vorlage:Clear/doc
This template adds <div style="clear:both;"></div>.
{{Clear}}
: Makes content wait until existing content is completed in all columns. Often used to stop text from flowing next to unrelated images.
Usage
This template should not be substituted. The markup provided will be confusing to many editors, and as this template provides documentation for itself, there is little justification for substitution. |
{{Clear}} {{Clear|left}} {{Clear|right}}
Example without the {{Clear}}
template
{{safesubst:#ifexpr:1>0|Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.{{safesubst:#ifexpr:1>10|
New section without template
See how this section starts at the right of the image?
Example with the {{Clear}}
template
{{clear}}
New section with template
See how this section appears below the image?
See also
- Template:Clear left (edit talk links history) delays content until left column is complete.
- Template:Clear right (edit talk links history) delays content until right column is complete.
- Template:- (edit talk links history) is similar, but technically different.
